I’m hearing very prominent ghosting when playing above the twelfth fret through my two NMV Marshall style amps.
I hadn’t noticed it until I moved to a new house but I’m definitely running the amps more open lately.
Apologies for jumping in on your thread @gpw5150 - I’d been meaning to ask for a while & your thread just reminded me.
You can get switching noise through the mains, especially if something is switching highish currents like TRIAC's but generally the biggest cause of noise is because the band is using sockets where there's a difference in earth potential and multiple paths to ground. Sometimes you can room area / stage with 10 sockets or so across but one lot might be ringed or spurred of the lounge circuit and one might be on some other ring circuit.
When that's the case try putting the whole band on the sockets that are on the same ring and in some cases on the same socket. Just remember the first 4 way plugged into the socket will take the whole load so make sure it's not a little 3 or 5 amp job.
As long as the extensions are correctly rated there’s no risk of overloading them. It’s best to use a ‘tree branch’ arrangement rather than a ‘daisy chain’ - ie a couple of heavy-duty 13A 4-ways plugged into the same double wall socket, then four more (possibly lighter rated) ones into each of those, which gives up to 32 available sockets, probably enough for most bands.
That`s interesting and very useful - thanks guys.
We kind of do this anyway, but should prob pay more attention to the ratings of the extension sockets.
