Incidentally, K&K do a jack for vintage guitars which works with a standard size strap pin, if you are concerned about drilling into your Bourgeois.
You would get better results with the later generations of IR based pedals that let you create your own IRs using a mic and whatever pickup you are using (expensive options: LR Baggs Voiceprint, Tonedexter cheap option: Nux Optima Air)
All the K&K really needs preamp wise is the right impedance and decent TMB EQ.
I'm not at all famillar with IR pedals having been out of playing acoustics live for 10+ years now. Will do a google
http://www.theboxwoodchessmen.com/
https://www.facebook.com/tingiants/?view_public_for=231700547508938
The EQ is inside, done with trimmers, you can tweak with a screwdriver
Definitely sounds ace with the preamp, but you can do as well inside an AF3 or FM9
The sound isn’t immediately obvious as an acoustic through a Metal Zone either, although it does make sense when you know .
https://www.youtube.com/watch?v=D8xWcTfcsSs
