It still needs a better speaker though. If you're on a limited budget I would replace the one in your DSL20 first - either with a Greenback or a Neo Creamback - the Creamback if you still think you might want to trade up to the 40 so you can keep the speaker, the Greenback if you definitely aren't going to.
Just fitting the H75 (or speaker of your choice) in the 20 will make a huge difference.
It's basically a four-channel amp with two pairs sharing an EQ each. I think Marshall undersells that slightly with the 'mode' thing. You get the channel 1 crunch mode which is superb, and two levels of drive on the Ultra Gain channel. Also the dual masters, as ICBM says. Pony up for the four button footswitch and you've got a very flexible amp with some great sounds in it.
I have no experience of the speaker in the 40CR, mine's the 2x12" 402CR which has fairly ordinary drivers in it. I have a cab with a Neo Creamback and that sounds great. Bang it through a Captor and some decent IRs and it sounds monstrous even at man-cave volume levels.
I keep thinking that the DSL is such a bargain that it ought to be easy to find an upgrade. E.g. the 2525c, a victory sheriff or Friedman Runt. But I really like the footswitchable loop as you can use it to switch multiple effects at once (e.g. eq and reverb for solo boost). And I've seen enough head-to-heads to not be convinced that any of those are really an upgrade.
Maybe I should just stick with what I have?
This is probably what you mean and I'm just reading this wrongly, but just to clarify, there's only one overall EQ for all channels.
