2 Amp into the HB, then the HB into the Boss?
Will that do it?
However, there’s a catch which makes it more complicated - you need to use a two-pole switch so you switch both the hot and ground connections, and the grounds are all isolated from each other, otherwise there will be ground loops between the amps which could cause hum or stability problems.
