So which unit has the best modulation and delays..
Something that competes with the Strymon mobius and either the time line/Boss dd500.
I've had line 6 helix, boss gt1000 ,and the stomps/cores.
Don't think either are as good as the pedals mentioned for modulation/delay. I had a fractal fx8 a few years ago and that was fantastic sounding . But I don't want to have outsmart the unit in order to make it good, and it was large. I don't want to have to apply EQ or adjust the input of my guitar, just plug it in, set up the routing and go...
Footswitch wise I think around 4 or 5 is the optimum number and would need an FX loop( ideally two..)..
Fractal fm3 would probably tick the boxes but seems a bit overkill money wise.
Is there anything else out there that can compete?
I'm not bothered about amp modelling, drives etc. really just want something that will cover modulations, delays, and hell why not some reverb as well
Not sure what you are missing in any sense.
The great thing with the Fractal products is the incredible level of control available to finitely adjust almost every parameter you can imagine. It means that if you have a sound in your head, you should be able to achieve it. I haven't come across any other pedal that gets anywhere close to the flexibility of the Fractal stuff.
!TheBigDipper said: Watched a few vids on the h90 it does look good. Is it a faff to program? People moan about the dd500 menu diving but tbh it's fairly straight forward and sounds great. The mobius is the only pedal I've come across where the factory presets are actually really good! Again tweaking isn't difficult on it.
I think the problem I've had with modellers is that I always find I'm wanting to tweak the sounds a bit. With the dd500/mobius I've set up a bunch of presets and then just left them in the main.
I'd say, desktop editors are easy to use on both, on device programming can be a faf until you're used to the process.
