Hi, I have a Fender Brad Paisley telecaster, I’m wondering about the saddle heights, they seem very high with quite a severe break angle over the back of the saddles.
The only other tele I have is a USA deluxe telecaster which has six separate saddles, this is my first experience with the three brass saddle bridge.
The action on the BP seems fine, not super low, slightly higher than my own tele, but it does feel a bit “tight” when bending strings compared with my USA tele. Both are fitted with gauge 10 strings.
Do these saddles look too high?
The bigger problem is that they're brass...
Of necessity, the three saddles of a vintage correct bridge will be lower at one end than the other. This tends to make the strings wriggle towards the lower end. The break angle over the saddle helps a little to hold each string in its correct alignment.
Also, should your strings be so close to the grub screws? The B string is sitting ontop of the screw?
This is a Rutters bridge & compensated saddles, which have relatively deep slots (maybe 1/3 of the depth of each string). But not a lot of difference between this and yours. If it feels good & sounds good then it's fine
It is the original bridge however I read somewhere Fender use different saddles on these now.
Good to see someone else’s saddles sitting above the sides, I think my query was from seeing other teles where the saddles sit low below the raised sides.
As for the b string I’ve tried moving it off the screw but it seems to slide back over time….I may get some new saddles and replace these ones ( what’s wrong with brass ones? @ICBM).
Also note to self, don’t take a silver sparkle guitar out into direct sunlight, think I just about burned my retinas out haha.
2) He knows that asserting this preference at every verse end winds up some forum Telecaster purists.
Hence, the winking smiley.
I just have to post that every time I see them because there is a widespread but completely wrong view that they're essential to the 'true Tele sound' - they're not, some of the most iconic Tele sounds have been done with steel saddles. In fact, neither is the three-saddle arrangement, which you will often hear the same about - six saddles sound fine too. Three, six, steel, brass, whatever - they all sound like a Tele as long as the pickup is mounted through the bridge... and I'm not even certain about that.
Also, brass saddles are a bit prone to indenting under the string pressure, which can sometimes cause intonation problems or sitar-y sounds - which may be why Fender stopped using them, although I don't know.
