I've got a few 3PDT switches lying round from pedal builds, which I could put in. Yes, it'll need a stereo cable. I've already got TRS connectors and a Hammond box.
How sure are you that they'll be latching? It makes sense now I think about it.
Does anybody have a Blackstar footswitch and a multimeter?
The optional FS-17 footswitch, or any 2-way latching footswitch can be connected
here. The first switch labelled ‘Mute’ will mute the whole amplifier, and the second
switch labelled ‘Reverb’ will defeat the reverb on both channels.
Sounds like a basic dual-latching footswitch should work fine. I could even put an LED and a CLR in series with each switch and see if they light up...
Thanks peeps.
Or: the LED is in parallel with the switch, so the light is on when the switch is open, and the current drawn by the LED is too small to operate the switching circuit in the amp. These often do have a resistor, in which case you need to know the polarity and the resistor value.
Without experimenting or seeing the schematic, it’s impossible to say which it might be.
So I can choose... LED on with switch closed, or vice-versa.
It sounds like the first option will be easier without knowing anything about the amp... if I get the LED the wrong way round presumably the switch just won't turn on the Reverb or whatever, as the inverted LED will block the current which would usually signal ON to the amp.
Have I understood that right?
So without seeing the schematic of the amp, I have no way of knowing.
You need to start by experimenting with an LED and a resistor and find out whether that alone operates the switching, or just lights up without doing.
