I think I would use a very small amount of quick-set epoxy, the stuff that goes rubbery before it sets hard. Coat the inside of the hole (sides only if you can) with enough to make up the missing amount of plastic, then using some left-over epoxy as a reference, wait until it's got to the point of being rubbery and not very sticky any more, press a spare pot with the right number of splines into it. You *should* then be able to get the pot shaft out again after it's hardened if you've timed it right so it doesn't stick to the metal.
NB - I've never done that on a guitar knob, but I have on an old bakelite door handle, and it did work.
