I’ve used the search function, read a few threads and I’m more confused than ever. In short, I’m sat here with a cracking set up, Vox AC30, Orange Tremlord and a host of great pedals (the kind of pedal board it’s taken years to get up to). Earlier I sat in the sun and thought: but you don’t plug it in for more than five minutes, you haven’t gigged since 2019, you are worried about playing past 7pm and upsetting the neighbours/kids. At which point I pretty much decided, bugger it all…helix looks fairly straightforward. Then I thought, but I’ll need an frfr speaker for those occasional jams with mates. A quick search of the usual retailers and I found passive cabs, or active ones at more money than sense. And before I knew it I was thoroughly confused.
So, collective fretboard wisdom of the hive-mind, where would you say I start on a moderate budget, what have you learnt in the last decade of using this gear? What’s good, what’s average and what’s best avoided?
Currently have an HX Stomp & Fractal FM9. I also have four valve amps and a load of pedals and used to buy and sell pedals all the time, searching for that elusive "tone in my head".
I can't remember the last time I bought a pedal since getting the Fractal (started with an AX8, then FM3 and now FM9) and barely use my valve amps. Personally, I'm a fan of the flexibility and convenience of digital rigs.
I've just joined a new band (only doing covers) and they aim to get in the ballpark of the sounds of the original track. With the Fractal, I just search what amp a particular artist uses, load that amp into a preset and I'm fairly close. Doing the same with the HX Stomp requires a lot more tweaking.
I know you are asking for a low cost of entry and the Fractal probably doesn't qualify. However, you should be able to pick up an FM3 around £800 ISH and I do think it is great value when you consider what it can do/ replace.
In isolation, the HX Stomp is also good.
I'm sure you know this but what you play it through has a big impact on how happy you'll be with the sounds you hear. Just as with guitar cabs, the "speaker" has a massive impact on the tone. Studio monitors are great for home use and stereo sounds lovely but if you want something you can play through with a band, the basic two choices are 1) running into a power amp and then to a regular guitar cab or 2) into an FRFR solution. I've used both over the years (starting with the KC350 keyboard amp) and have gravitated towards FRFR solutions as I find they give me more tonal options with IR's. I've settled on a handful of York Audio IR'S to reduce option paralysis. I typically also only use mono live.
I used a Yamaha DXR10 for a long time but recently picked up a Fender FR-10 which is all I've used since getting it, either at bedroom volume or at band rehearsal. Sounds great in either scenario. Both options cost less than £350. I haven't tried it but many like the Laney equivalent of the Fender.
Apologies for the long reply but hope it helps.
I did a rehearsal today using my HX Stomp instead of the FM9, having replicated a handful of basic presets using the same amp/ effects ( as an example JCM800, SD-1, Vintage Digital delay, Dimension Chorus and the same York IR in both units)
Within less than 5 minutes, the other guitarist commented that it wasn't sounding as good as the FM9 and it simply wasn't. I'm sure I can get it closer with tweaking but it's not as instantly gratifying.
There is some reports of the Fender FR cabs hissing but in all honesty, mine is not bad at all and hasn't had the "stealth" Fender hardware "update" - check out the 100 page
"Hissterectomy" thread over on the Fractal forum for the full story...It does also highlight how well it compares to a range of other (often more expensive) FRFR solutions.
I don't use the Helix live these days as I'm not currently in a band and my last one was playing bass in a big band jazz band. Bass / Flatwounds / Amp was all I needed.
I have used the Yamaha DXR10 powered PA speaker and I thought it was pretty good but I think if I gigged it again I'd probably go down the route of a power amp and a trad speaker cab unless the band was an 'everything in the PA + IEM for monitoring' band.
HX Stomp
or
FM3/9
I bought a used one of these Yamaha THR100 HDs when not using my big heavy amps which is 99% of the time. It's brilliant.
https://www.musicradar.com/reviews/guitars/yamaha-thr100hd-628051
Modelling is great, and I have a GT-1000 going into studio monitors, but I use a DSL40 for home 90% of the time.
If you do go the modelling route I think FRFR is disappointing it's like a random extra bit of PA not attached to the mixer. Either go silent stage with in ear monitors and let the PA do the guitar, or play your modeller through a guitar cab (which feels and sounds much more "real") and then take a feed with an IR through the PA.
Nah. Lots of people are still happy with theirs.
You can disable the cab profile and run into your amp, or you can use headphones, or you can use monitors, or FRFR...all for the price of a distortion pedal. It's insane how good this thing really is. It basically turns your normal rig into a modelling rig, while taking up less room on your board than the channel switch for your amp.
It doesn't do any of the really clever stuff the Helix can do with routing, but...do you actually need that? Don't get me wrong, the Helix is still a phenomenal piece of gear and (in my opinion) sounds just as good as all of the competition. However, you do need a very clear picture in your head of what you want to achieve with it; if you think you might get option paralysis, it could cause more problems than it solves.
I think this is potentially all coming down to needing a quality sounding headphone option as a starting point and maintaining everything else as is for the time being. Small steps and all that.
