Now you guys are going to have a field day with this!
I currently own a fabulous limited edition blueburst Epiphone 335 with Gibson 57 pickups coutesy of
@RichardsGuitars but sadly haven't had an amp to play it through.
I inquired about an amp today from my local music shop, initially I went in looking for small all in one amp, something like the THR5, Mini Mustang, but they gave me a nice demo of the Fender Superchamp x2, had a good chat and came away needing to think about whether I want an all in one, or a basic (possibly tube) amp and to get some pedals.
However I still needed something to practice through. So I took an executive decision and had a quick search online. I proceeded to spend not a lot (£39.99) on a 20w Acoustic Solution amp from Argos.
:-). Go on, rip me to spreads, I know you want to!
My initial thoughts are, it's quite basic, gain, level, bass, mid and treble. The finish of the control panel is understandably poor due to its mass produced nature, but......
...it sounds ok, it was a 12th of the price, its small, it's not loud (a major criteria) it's actually all right for a practice tool. So those of you that have spend hundreds on your amps, put that in your pipe and smoke it! (I am joking as I would love a Vox AC30 #well gel) and the last person I met had an amazing! Marshall amp, this is really just a stop gap)
The main reason for buying was that I wanted to work on my technique (finger noise etc) before plunging into buying a nice amp, last time I checked it was quite bad). The second was that I want to play around with the idea of pedals (never used one) rather than having an all in one. With this I can try some pedals in front of the amp, delay and reverb were the main, but the 335 actually gives off some natural reverb on its own.
So there we go
I have some lovely amps, but usually practice at home with a £63 Belcat from Gear4Music. It sounds fine, in fact it has a couple of tones I wish my gigging amps could get.
I will certainly be needing some advice on something a little more special in the future (and pedals for that matter), but I just want to get more confident with my playing.
The person in the shop asked me if I wanted to try an amp and I passed, even though I was itching to, I just didn't feel confident enough, even if I buy second had locally my fingers just seem to freeze.
Mind you they are dearer than what you have just bought but I certainly don't irritate anyone with my widdling
I had to learn so much about how and where to hit the strings, about dynamics, touch and expression because it's all I had.
Don't get me wrong, I'm no genius, but I wouldn't be half the player I am now if I'd had access to thousands of different sounds while I was learning.
Keep it simple and maybe add the occasional effect one at a time, then you'll really get to know and appreciate what you and your gear can do.
It's solid state isn't it? eh! You can't deny it. Sorry but you're now dealing with the pro's on these boards and only valve or serious modeling amps are acceptable!
It's a bit like listening to Radio 1 on a really good stereo, the way they compress it makes me feel seasick after a while.
An expensive solution if you don't have an iPad
