I have never had this question answered properly. We all know that a 100 watt Marshall amp is not twice as loud as a 50 watt Marshall amp (the same for any other brand for that matter). It will probably be cleaner for many of the lower to middle volume settings and it will probably be louder at full chat ..... but not twice as loud.
However, would two Marshall 50 watt amps, side-by-side, be twice as loud as one would?
Logic would tell me that would be more or less true - maybe not completely twice as loud, but getting there.
Money, guitars, cars, football, beer and women - roughly in that order. Also, black things are good. All hail the Lords Black, Burnel, Cornwell and Greenfield - and Squire Warne. Currently levelling buildings with a Precision bass for the unrivalled
www.daphnedontfloat.com
Bandcamp
Spotify, Apple et al
Def Leppard tried that. I'm not sure it worked ...
30 watts is 86% as loud as 50 watts.
25 watts is 81% as loud as 50 watts.
22 watts is 78% as loud as 50 watts.
20 watts is 76% as loud as 50 watts.
18 watts is 74% as loud as 50 watts.
15 watts is 70% as loud as 50 watts.
12 watts is 65% as loud as 50 watts.
10 watts is 62% as loud as 50 watts.
9 watts is 60% as loud as 50 watts.
8 watts is 56% as loud as 50 watts.
7 watts is 55% as loud as 50 watts.
6 watts is 53% as loud as 50 watts.
5 watts is 50% as loud as 50 watts.
4 watts is 47% as loud as 50 watts.
3 watts is 43% as loud as 50 watts.
2 watts is 38% as loud as 50 watts.
1 watt is 31% as loud as 50 watts.
I turned it to half way and found I couldn't hear it.
It took me three days for my hearing to come back.
You have be careful to keep the same power going into the same speakers.
If you compare a 15W amp into a V30 to a 50W into the same speakers the latter will not be quite as loud as it might be because of thermal compression.
To do a scrupulously fair comparison you would need a bank of speakers of about 500W rating in total so that the amps never get close to compression any individual unit.
BUT! A big bank of speakers will have a very tight polar diagram so where do you stand to be deafened?
Dave.
You might need to experiment with separation and orientation of the two amps.
No way would a modern Marshall be able to manage that.
If your eyes can stand it, this is a sort of visual representation of what happens as the sound waves spread out from two speakers...
https://figures.boundless.com/11111/full/two-sources-interference.gif
The different colours represent different amounts of addition or cancellation. This is for one frequency too, it becomes almost impossibly complex with a mix of frequencies - but the end result is that the sound is not the same at different places in the room. You might need to try different separations or even have the amps pointing in different direction, or stacked on top of each other, to try to minimise it.
The other option, I would be looking at is running through the PA - if the amp is loud enough to keep up with a drummer, then for bigger gigs I assume the drums are mic'd and you could feed into the main PA rather than getting louder on stage.
Things are even more complex than your mind bending diagram suggests ICBM!
That only show the original propagation, in practice those waves will strike a surface and come back and interfere with the new outgoing waves and this will produce complex, "standing wave" patterns.
Upshot of that is that NOBODY can get a perfect rendition of ALL frequencies!
Dave.
*In independent tests.
