After this weekend, all (or at least most) of the decorating will be done and i will have time to delve into my new G3 properly. One of the things i want to try is recording using it.
Could someone who has done this already using one of these give me some guidance as to how to do it?
I have never ever recorded anything in my life and barely had a chance to discover much about the G3 except some of the amazing sounds it makes. I have read that some people use software called 'Reaper' but i was given Sequel LE with the unit as a freebie - Which of these would be better to use, or is there an entirely different one i should use. I believe i then need a 'Soundcloud' account - this is something else i have never had or used so although to those who do this, my questions might sound dumb, it's just unfamiliarity and any help i can get here will make it easier to understand.
ANY help with this whole subject would be greatly appreciated.
Thanks.
Forget Sequel IMHO. I dldd a demo some time ago and wasn't impressed, more for the cut and shunt merchants than making "linear" recordings.
Yes, go for Reaper. Free until you can't stand the nag after 60 days and as easy to use as any DAW (which is actually not a lot!) and easier than many.
Don't know the Zoom G3 but they are a top company and I ma sure have good documentation and helplines?
You don't need a "Sound cloud". It is used to move big music files across the internet but you can use Dropbox or any other of the suchwhich.
Dave.
Now I can get one for £2.99 which will work but there are also cables which are 'Audio Grade' and have copper strands, silver plated contacts and all kinds of other nice sounding stuff for £35.00
Now yes I know the expensive option will be better but how much better?
To put the question another way, while I get used to practice recording, will the cheap printer type work okay or should I just not bother until I can get the decent one?
Is the decent one just snake oil?
That's the one to get unless you like the smell of snake oil.
You will also need to install the ASIO[*] drivers for the G3 on the computer from here:
http://zoom.co.jp/downloads/g-asio/software/
3rd for Reaper. It's a steep learning curve, but they all are. Reaper just works, though - rock solid. There are also a shed-load of tutorials, etc. on yew-choob.
Get the G3 drivers installed & plug it in before you start Reaper. You should be able to choose the G3 from the 'ASIO' input devices in Reaper. By default, this will probably also be your output device which is OK as long as the G3 is also connected to an amp. If not, you should be able to select your sound card as an output.
There is a good guide here: http://wiki.cockos.com/wiki/index.php/Reaper_Documentation
Resign yourself to being as confused as hell for about a day and a half, but keep plugging away at it.
[*] remember it, but don't worry about it. N.B. If you've installed the Zoom ASIO drivers (as above), you *do not* need to install 'Asio4all' as often recommended...
It is totally unforgiveable to sell a product such as a USB interface without the correct cable.
USB A to B leads are ridiculously cheap* (2 mtr, A 2 B cpc.co £1.88) . I have read that even HDMI leads cost well under a $ to make so how much a USB?
For a cable 3mtrs or less buy as cheap as you can. I have had only one issue with cables. My NI KA6 interface would not lock on an old XP computer with one 5mtr lead but was fine with another brand. On Win 7 either cable worked fine.
Dave.
When I opened the box I was a little disappointed. Even a TC electronic tone print pedal comes with a USB lead and given the function of the Zoom G3 it doesn't make sense to not include one.
I don't so much mind the extra few quid cost but having to order one separately isn't a great idea on their part.
Was I just unlucky or do they really not include one? I've been presuming this so far but it could just be mine that they forgot to put one into !
