This is regarding the Roland Cube 80XL in this thread.
I bought it in April 2014 from Gear4music. I only bought it primarily as a S.S back up amp to my Bogner, so it's been played through very infrequently. The further details are in the OP of the above thread link.
Basically, from that thread, especially ICBM's expertise, I have gathered it is unfit for purpose, even a replacement would be pointless as I need something that will handle the job. Now, the Shop(Gear4music), said I am only entitled to have the amp repaired or replaced, this will be undertaken by Roland U.K.
Are they flanneling me? How long do you get under "The Sale of Goods Act 1979" to return something faulty? I've gathered that the law does not actually state a definite period of time re "accepting the goods".
I can't help the fact that I was unable to put it through it's paces until 8 months after I bought it, I wasn't in a band back then so it only got played at low volume and very infrequently. I was under the impression that the amp would easily hack it, but it crapped out before 2 rehearsals were completed.
Simple question really, what are my odds?
Thanks.
Only a Fool Would Say That.
Although I would say, I didn't "change my mind" . I just didn't "find out".
You might be able to argue your case from that skiing example point of view, at least under the old rules (buying it as a backup to use in a band, through no fault of your own your band only got together now so you couldn't test it in that situation till now- especially if you asked, when buying it, if it would work for the band situation).
Unfortunately the rules have changed recently, so I'm not sure where you stand now. And like most legal stuff, just because you're (maybe) entitled to it doesn't mean the shop will just fold immediately, you might have to push.
Maybe take a look here to see if they can help: http://www.adviceguide.org.uk/consumer_e (and more specifically, here: http://www.adviceguide.org.uk/england/consumer_e/consumer_common_problems_with_products_e/consumer_what_you_can_do_about_faulty_goods_e/faulty_goods_-_if_you_want_your_money_back.htm )
Can you contact Citizens' Advice? That's what I'd do. Send them an email outlining the problem, and hopefully they can give you some idea of whether a refund is reasonable or not, legally where you stand etc. (especially point out the bit about not being able to try it in a band situation i.e. high volumes until very recently).
EDIT: http://www.adviceguide.org.uk/england/about_this_site/contact_us.htm
http://www.gear4music.com/information/returns-and-refunds And Guarantee & Warranty
If the design is a bit marginal, it's only that - not poor enough that a failure is a certainty or even a strong possibility. To prove lack of fitness for purpose you would have to show evidence of a design fault which made failure more or less inevitable sooner or later, and that's definitely not the case.
I actually can't think of a modern guitar amp which would warrant a claim as not fit for purpose, although there are a few which might be getting a bit close! But it depends on how you define 'purpose'. They might argue that running overdrive and/or boost pedals into the front of an amp which should already have enough gain falls outside reasonable usage. (Wrongly in my opinion, but I'm not a claims lawyer.)
If the fact that you run a 100w Fender Frontman 2x12 with the volume on 8 is any indicator of how loud you need an unmiked amp to be, then I'd guess that the Cube which blew up on you is probably fit for most purposes other than yours.
Purely an afterthought, but is there any reason you can't mic your amps, I assume you must have a PA?
During the first 6 months of guarantee its up to the retailer to prove a fault hasn't existed from day 1, in the next 6 months it's down to the customer to prove a pre existing fault. You'd have to pay for an independent engineer to produce a report on the fault and submit that. Roland would then have a chance to let their own engineers look at it. The whole process would take a long time you'd still be unlikely to get a refund.
By all means push the retailer for a refund and if they cave congratulations but they have absolutely no legal responsibility to do so. Personally if it was an 8 month old product in one of my stores I'd be repairing or exchanging it as well.
