Hi all. I am thinking of putting new power valves in my Marshall JTM 45. Im a bit confused at what valves to get. Marshall say 5881 but isnt that the same as 6L6GC? 5881 seem hard to find. What would be a good valve to go for. Im looking for early breakup and a full distorted tone. Another question, when biasing would I use the amps rated output of 30 watts (15 watts per valve) or the 23 watts rating per valve (for 5881). Biasing at 60% dissipation should I use 15/423*0.6 = 0.021 or 23/423*0.6 = 0.032 for 5881 valves or should I use 30/423*0.60 = 0.042 for 6L6GC. There is quite a difference. I know the valves would handle the higher but what about Trannies etc as the amp is rated at 30 watts.
Iv also read that plate voltage must be below 400v for some 5881 (Tung Sol). My plate voltage is 423v. Would 6L6 be better suited? many thanks. Scott
I've got a pair in my Satellite Barracuda and they are incredible!
Eqd Speaker Cranker clone
Bo
It's an ideal use for them since they aren't really sturdy enough to hold up well in normal 6L6 amps (eg Fender Twins).
