1980 Marshall 2104 Master Volume 2x12 Combo
Marshall JMP Master volume 2104 combo with original celestion g12-65's. Great sounding amp just had a service Dave at Rosewell amps so you don't need to worry about changing anything. The amp did have a slave out on the back, the panel is still there but internally it has now been returned to stock. Exactly the same as the 2204 heads, would just need a head cab if you wanted to convert it and it would work out cheaper than buying a 2204 and that doesn't include the G12-65s!! £500. York.
