So, possibly the exact same pickup as the bridge and a treble pass cap? Or even a high output neck, lower output bridge.
Other than that, a drive pedal would be my best guess... Something that cuts bass, like a tubescreamer (bad monkey?) and has volume enough to get a bit above unity. Even that will add a bit of grit - perhaps an eq pedal could work?
Actually an inherently louder neck pickup with a treble-pass cap might do it, yes...
technique can help. try picking close to bridge on neck pickup to give more attack , and play softer on bridge pickup closer to the neck. Watched Will Kimbrough do all this years ago at a gig, total revelation in tones from one guitar.
Using Tone control on bridge pickup at half setting, then set amp up for usual tone. this way you can go brighter on neck pickup if you want or go for nice warm tone with clarity with tone just backed off, all these things help. and are easy to try and free !
It's not technique, I always play close to the bridge, even on the neck pickup. There is a cap in line, but I don't know its value. It is green though! )
Basically... if we're saying the typical bridge pickup is like a sawtooth "fence" sound, then my neck sounds more "bell" like, but with ridiculous amounts of low-end, even on the coil-tap. The pickup is quite low too, it's not really near the strings it's mostly in the body!
I think maybe I need to explore my electronic options. Don't want to do it with pedals.
@Drew_fx The pup's on my Jackson sound almost identical.
The neck is a Duncan Distortion (Ie Ceramic) and the bridge is a @Clarky spec Bulldog Extremist (Ie Alnico 5).
The neck is almost flat with the body, where the bridge is quite close to the strings. There is no volume difference set like this when you switch from one to the other. The neck is a little looser and less focused, the bridge is a touch more focused, and a little brighter, but that's probably more down to the different pup's.
