Some nice EB Musicmans have the piezo... some gorgeous Axis Supersports & John Petruccis have them.
I have a cheap & cheerful Peavey Generation EXP with ACM acoustic (Tele shape) that does the same thing without spending a fortune. Play humbuckers/acoustic emulation or blend a mix of the two. Sounds decent enough to me.
Think there are some tasty Godins about too though know nothing about them
Cheers Baz
+1
The other option is to fit a graphtech ghost (or similar) system - I put one in a prs and it works great - it would open the option to use one of your exisiting guitars and not be tied into looking at a limited selection that have them pre installed.
I ordered them direct - as I couldn't find a uk dealer (that might have changed). I replaced the bridge saddles and there's just enough space in the cavity for the circuit board and battery.
The wiring is easy enough as the cables just clip into place on the preamp board. You could swap the tone control for a push/pull pot to switch it but that won't allow a mix of tones - I ended up adding a mini toggle to give the blend option as well.
There is the option to leave the acoustic volume preset or add a volume pot but on a Cu22 that would mean adding another pot or losing the tone control.
The package came with a stereo socket so you can split the output to seperate amps via a Y cable but I usually just use a regular mono lead - through a lot of guitar amps that doesn't sound anywhere near as good though. I often gig a fender twin and it works better than most amps so you might want to think about how you'll amplify the acoustic sounds...
Years ago I use an x3live and had two inputs and outputs which was nice.
StefB has a good point... a Roland strat (if you are a strat player) through a Roland GR20 or the like will give you from nylon classical right up to 12 string options (plus piano, organ, saxophone & the whole synth works).
This guy gives a good insight
http://www.youtube.com/watch?v=cVwM-3Duy8U
I assume you are in Wales ? So far away or you could have tried the Peavey & the Strat/Roland set up as I have them all here
Here is a good demo on piezo on EBMM JP6
http://www.youtube.com/watch?v=OqnymSwExzU
Fun hunting down new toys isn't it
Cheers Baz
No, but I'm watching it on eBay so thought I'd suggest it. I have three piezo equipped MusicMan guitars - a Silhouette Special, Albert Lee and an Axis SuperSport P90. Can't recommend them highly enough, but they are quite a bit dearer than the Godin and aren't for everyone due to their diminutive size and fairly narrow neck widths.
Nil Satis Nisi Optimum
http://www.andertons.co.uk/solid-body-electric-guitars/pid20451/cid671/epiphone-ultra-iii-les-paul-in-vintage-sunburst.asp
I can vouch for them being decent, but worth a pickup swap. 2 outputs iirc, so you can run it to pa and guitar amp.
It also has a tuner in the pickup ring, something I think is really nifty.
