With so many comparison web sites out there, how do I choose the best one?
I actually don't like burst buckers at all, nor the 490 whatever they are things. 57s are nice but if they work for you.
Heard many great things about mules, but don't feel the need to get pickups from anyone but oil city
Also, I envy you guys the r7s
The great thing is that there's a massive range of tones available from the mainstream players and the small guys ... there'll be something to please everyone somewhere
I think the mistake alot of people make with Gibson burstbuckers is not realising there are 2 distinct flavours. The Burstbucker 1,2 & 3 as normally seen on historic reisses use alnico 2 magents and will have a softer bass/top end. Then there are the the Busrt bucker Pro which are seen in USA standards and they use alnico 5 magnets and have a tighter bottom end but more trebly top.
skay, I suspect your R7 may have had 300k pots (as standard on historics until the last few years) may have made the pickups sound muddy. I know the Bareknuckle wiring diagram shows hookup with 500k pots. When you changed the pots they were probably at least 500k or 550k which do make a difference. Even current historics that have 500k pots are within a tolerance and I've measured them as 440k and 480k in my 58.
I've also found with Les Pauls that pickups that sound good in one may not sound as good in another LP. There are tool many variables, however it is fun try out the options ;-)
Burstbuckers (1 and 2) are great pickups. Hard to get a bad sound out of them IMO. But some of want to be just a bit nearer to the original design, and I am also experimenting with PAF types in an old Les Paul.
This is great fun, but I have realised something over the years. The reason why original PAFs fetch crazy money is because of that sticker.
But hang on a minute - why do the early PAT No pickups (same as PAF) fetch silly money when they don't have the magic sticker.
It is because they sound incredible in the right guitar.
I guess that is why everybody is trying to clone it.
1. Gibson bought in several different grades of alnico in the at that time ... notably 2, 4, and 5 ... and used them fairly randomly on their humbuckers. Whatever was in the magnets bin that day got used.
2. Although the winding machines should have had automatic wire traverse: whereby all the coils were laid in tight machine patterns ... in practise the operators had to take control pretty regularly as the machines tended to wind odd shaped coils if left to their own devices.
3. The timing gears on the winding machines used to strip on a regular basis ... this meant the bobbin drive wouldn't shut off automatically after 5000 turns. So rather than have down time on their machines, the operators used to 'time' the bobbins to 'full' or judge them by eye. hence combined coil resistance can vary between 7.3k and 9k for perfectly authentic PAFs. Sometimes they even used the more powerful pickup in the neck ... as they were all meant to be the same ... they weren't even 'handed' as far as which side the output wires emerged.
Now try and tell me which real PAF is the paradigm? The answer is there isn't one.
I have played lot's of old Gibson guitars and tend to assume that the differences are always coming from the wood.
Maybe modern pickup makers should be aiming for this randomness (the healthy used market should be able to sort out anybody who is disappointed)
Maybe you already are aiming for that!
@mcsdan I measured the pots that came out of my R7 when I did the swap and they did read a bit low for 500k (around the 450-480k IIRC, plus they had 500k stamped on them, i'm going back seven years here though...) so the Dr Vintage overspeced pots that read just over 500k probably did change the sound of my Burstbuckers but not in the way you would expect.
Surely if the pots are rated higher then MORE treble comes through, so i don't know if the harshness went away because I had inadvertently changed the height of the pickupswhen re-installing them or just got better at dialing them in after all that messing sround with the BKP? I know that the pot taper was vastly improved and I love the way I can now go from 10 to 9 on the volume pot and actually hear a slight drop in volume but with still with clarity that it's made the guitar much more versatile live.
Another good point made above by a few posters is about the magnet type affecting things. The Mules use alnico IV magnets, so Tim from BKPs suggested that the added midrange was what I was hearing and possibly didn't like (especially coupled with the pronounced upper mid-range of the Vox), so I tried the Stormy Mondays afterwards which were alnico V I think, but I found the same issues occured with those as well.
We eventually got around to discussing him making me a custom alnico II set, as he thought maybe it was the scooped midrange of the Burstbuckers was what I liked, but I politely declined as £200 would have been a lot of money to basically have replica clones made of the pickups i'd be replacing!
Anyway, from @Barney confessing his love for some new pickups, this has grown into quite an interesting discussion
what difference will it make to the volume control for 50 s wiring ..?...thanks
Stormy Mondays are Alnico 2 (same as my own Blitz Spirits) which have a mid 'hump' compared to an alnico 5 pickup.
As a general rule:
Alnico 2 = slightly unfocused bass end ... some would say flabby. Mid hump soft singing treble.
Alnico 4 = more focus in the bass around the same mids as alnico 2 ... and a little more top cut. Overall very even balance (that some find boring).
Alnico 5 = fat bass, somewhat scooped mids, stinging ... sometimes a little over the top highs.
Alnico 8 = a high output version of alnico 4's EQ
Oh ... and people confuse alnico 2 and 3 ... 2 is actually magnetically more powerful than 3 ... which is the weakest magnet commonly used in pickup making.
