Anyone know about disconnecting a battery from a mk4 Mondeo?
jonevejoneve Frets: 1477
Need to hard reset my Stereo in my mk4 mondeo (with Sony DAB) as the phone function has magically disappeared/stopped working, and this fixes it, apparently.
Is there a simple way to disconnect and reconnect the battery without buggering anything else up?
Cheers!
  • mike_lmike_l Frets: 5700
    The radio might need to be re-coded, usually a 4-digit code, but other than that you should be good*.
    Make sure you have the radio code before disconnecting.
    *disclaimer, I can't think of the top of my head anything else.
    After you disconnect the battery  you usually will need the 4 digit code to get the radio working again.  If you don't have it you may have to pay to get it (you can usually buy the codes on eBay).  Just check before  you do it....
  • NomadNomad Frets: 549
    Can't you just pull the fuse for the radio and reinsert it?
    Nomad
  • SambostarSambostar Frets: 8745
    There is a free program on the internet somewhere that gives you ford radio codes from the serial number
    Backdoor Children Of The Sock
  • BigMonkaBigMonka Frets: 1783
    Sound like a smart way to go as it won't affect anything else (it will still require the PIN number though)
  • jonevejoneve Frets: 1477
    This sounds wonderful - how does one achieve this?
    Also, I have the radio code, so no problem there (well, I have a card with the 4 digit code on which came with the car, so I assume it works!)
    I can't imagine it involves much more than finding the fuse that's in the power circuit for the radio, removing the fuse, and then putting the fuse back in. There may be a need to keep the fuse out for a while in case the radio has a way to retain its settings during short losses of power. If it has, the owner's manual should mention it.
    Nomad
  • chillidoggychillidoggy Frets: 17137
    edited March 2015
    Don't do it unless you have the radio code. I did, and Ford wanted £25 (I think) to reprogramme it. I found the code in the end, though.
    Try holding down 6 and press 1 after scrolling through screens the radio should display it's serial number.  Try the generator to see if you can get the code before you pull it.
    Or try here.
    http://www.justanswer.com/uk-ford/7c0o1-ford-mondeo-tdci-140-radio-code-mondeo.html
    I got the code for the radio for a couple of my Transits from the generator programme.
    Didn't make any difference though, I still couldn't hear it over the noise of the 2.5Di engine.
  • holnrewholnrew Frets: 8207
    You might need a 4 digit radio code. HTH
    My V key is broken
    Therein lies the problem - I have located the fuse box under the glovebox - but there is ZERO indication as to which fuse is which (I know it's 'F6' that I need), and there's NOT ONE diagram of the central fuse box layout anywhere on the internets. (though there's plenty of the engine fuse compartment and the rear fuse compartment!)
    FUCKSAKE!
  • Paul_CPaul_C Frets: 7852
    there's an image of all three fuse boxes in the owner's manual pdf on this page, any good ?
    http://www.diagnostic-world.com/pages/ford_pdf_user_manual_212492.cfm
  • jonnyburgojonnyburgo Frets: 12426
    Have you tried hitting it? It used to work on my Grandad's TV
    "OUR TOSSPOT"
  • bazxkrbazxkr Frets: 616
    Why not just disconnect the earth terminal
    Do what you have to do and then reset
    Paul_C said:
    Legend, cheers mate - I googled for about an hour and couldn't find this!
    Will have a go at fixing this at the weekend.
    Speaking of which, when are they bringing Bread back Jon? :)
