Been looking casually at things like the Tone King's, Carr's etc and whilst having my daily staring contest with the Coda website jumped on a few demo's of the Redplates. I've heard of them in passing but never delved into it but the YT demo's are very inspiring, kind of looking for a grab-and-go combo that will be used mostly at home, I have zero idea if this is the realm of Redplates, also the model's aren't exactly straightforward, almost all the ones on Coda's site seem to be missing from the Redplate site itself, very strange.
I really like the look of the RP50 but think it might be a tad expensive and loud as a mofo for a small clean combo for home use, especially as the Matchless doesn't look like it has any interested parties (Oh damn, looks like I'll have to keep it then......;-))
Anyway, just fishing for info and experiences, the search turned up some results that were mostly classifieds, hence the post.
Cheers you luscious lot.
TGP
The amp itself is beautifully made. I had it out of the shell last weekend to sort out the reverb (the usual dodgy connection in the accutronics tank) Took some photos of the guts. All handwired, and considering how much is going on in there, very neatly done.
So what do you want to know?
Hi mate, just really wondering if these are a versatile home/small gig crossover amp? All the demos seem very interesting but they never tell the full story about volume, tweaking etc.
My situation is that I have just quit bands for a while, probably a good while! My usual rig is a Matchless Independence into a 2x12 and it's an absolute beast live for just about any style, alas it is *not* portable and definitely is not a home use amp as it needs the power section humming to get anything like a nice tone.
I'm after something that is portable, small gig worthy but good at lower volume, takes pedals well, has plenty of headroom but isn't the usual Fender decapitation bright.
I'm considering a trip to Coda to try a few but its over 200 mile each way from me so it would be nice to get an idea before that happens.
PS: your images don't appear to be showing?
I use it with the clean set warm and full and then have the OD to just push it a little so it cleans up with pick attack. It will do loads more dirt but like most Dumble style amps the dirtier tones are for lead rather than rhythm. The tone sculpting controls are pretty wide ranging, with bright switch, Mode, and a couple of local negative feedback switches on the back in addition to the tone stack.
TBH the amp is too good for me, I'm not a good enough player to make it do my bidding (many people say the same thing about Two Rock amps, they are very revealing of poor technique) without it making me look sloppy.
When it was in the 1x12 Combo it was very portable, but I like the breadth of tone a good 2x12 gives. I have tried it with a few different cabs and like most Dumbles it likes a big cab. It is certainly gig worthy, with loads of volume on tap, and I run it through a Hotplate to quieten it a touch, and with this type of amp they work well down to about -8dB.
Having also given up gigging I'm not sure I'm going to keep this, I also have a DrZ EZG and a Ceriatone OTS which all did the same sort of thing as a clean base for pedals so at least two of them are going to have to go. I intend taking the BV to our next jam session to give it a direct comparison to my OTS. It think the BV will best the OTS but I am very loath to get rid of it as I built it and modded it quite considerably. The Dr Z is most defintely a gigging amp, it is very good indeed when wound up, but does not have anything like the tone shaping capabilities of the the BV.
In my experience, it is difficult to get an amp that will yield up a nice tone at low volumes and be capable of sustaining that at gigging volume whilst still being good at handling a push from a pedal in front. A lot of what I like about an amps clean tone ( and I suspect others do too) is the harmonics that are generated when a gain stage is pushed just a little. And I think its also the case that a power section that isn't really working doesn't sag quite as I'd like, giving a hard stiff response. So a 5-7 watt amp at home, at reasonable volume (still quite loud obviously) will yield some of those characteristics, unfortunately at gig volumes, with pedals in front its going to become a bit strained, probably sagging too much, maybe a bit too much compression from the gain stages and just a bit too much distortion when you pick hard.
My experience of Attenuators, Power scaling etc is that they only give up the goods provided you dont ask too much of them. So I'm sorry to say i think you need more than one amp! Alternately just find a really good pedal that you can put infront of your gigging amp, at low volume, and leave it on, at home. They do exist.
He addresses some of the problems that we have all faced, and it echoes my own journey... I searched for years for an amp that i. Provided great cleans ii. Could be made to bloom, overdrive, clip, provide harmonics (or whatever phrase that you prefer)... And Hywelg is right, you need more than one amp for this !
You simply have to play them to find the sound in 'your' head. Coda stock many of the good and great, and I settled after mucho spending on 2 Carrs... A Rambler (stunning cleans) and the Skylark (the best 'home'/small gig out there imho.
Right, Redplates... Hmmm, Ive had a love/hate relationship with them. Let me say right from the outset, THE best sound Ive personally ever had was through a Redplate CDS2, or maybe it was the Blackverb. Anyway, the do get that 'bloom' for me at low volumes, but (like all of em) are much better when driven.
I have had some quality issues with them unfortunately, but I guess that could happen with every amp. I rate the bigger size Redplates best - the transformers are bigger - and id try a RP Blackverb, Cds3, RP40/50 and def the Carr Skylark and Rambler.
Doug at Coda is amazing. Yes, it is a bit of a bastard to get to (!) but his service and patience are superb. Feel free to ask any more questions.
