So I finally got around to buying an audio interface for my PC, and thought I'd record a a little clip of a couple of the tones the amp can produce.Forgive the playing, I'm just noodling between adjusting things. Disclaimer: I don't own a decent set of studio monitors, so I've got the mic position so it sounds the same through my speakers as it does in the room.
I'm using a 52 Hot Rod Tele, initially neck then bridge pickup, and running a Nova System in the loop for a little reverb and delay. The amp is in EL34 mode. No post processing.
This next uses no external effects, on the 6V6 channel of the First Lady, and playing a Gibson SG with 57 classics in the bridge position. Again, no post processing.
Lastly using the same settings as the 6V6 clip, but in EL34 mode. Gibson SG again, first half is the bridge pickup, second half neck pickup.
I'm working on a replacement. Probably should start a thread in the Made in UK section......
