In this case he's made the red wire the coil split connection - that gets switched to either ground or the pickup hot (where he's connected the green wire) to bypass one coil or the other. You can do that just as easily with a push-pull.
It's not a great idea to do it with long unshielded wires though - these guitars are already fairly poorly shielded and it will cause noise - ideally you need to use a shielded cable. If I remember rightly the stock wiring has 4-conductor cable on the pickups, in which case it's already done for you and you just need to access the coil split connection at the control end.
An alternative method is to connect the coil-split connections to the unused terminal on each tone control, which will give you the single-coil sound when the tone is on 10, the humbucker when it's on about 8, and normal tone control below that.
