I don't know if it varies from pedal to pedal, or whether a greater variation is easier or harder to interpret , so I am interested in this thread - sorry I can't add to it
So if you've a 25k pot and you stick a shim of wood under one side it's not going to go to 25k but that's okay when you calibrate it, it'll take whatever the top value is as it's top value.
If you're talking non-digital pedals they use voltage controlled inputs for their effects pedals so for them the actual value of the resistor is probably more significant.
If it's used as a simple variable resistance (mono plug) then the 25K will stop doing much when it gets above 10K on a system designed for 10K and a 10K will only give 40% of the range on a system designed for 25K.
