For sale is a used Marshall JCM800 2203x Reissue 100W head in almost immacualte condition.
If you are reading this then likely you know what you are looking at suffice to say these are a hand built version of the JCM800 with the addition of an effects loop that can be removed from the circuit. It built like a tank and constructed in hand wired fashion so that maintenance and repairs are simple with pots and valves not being mounted on PCB's
Here is what Marshall have to say;
This JCM800 re-issue, 2203 model (’81–’84), is one of the most highly respected 100 Watt Marshall heads. Originally evolving from the ‘Plexi’ head, the JCM800 was one of our first amplifiers to feature a Master Volume control.
The JCM800 2203 remains the essence of simplicity; it has one channel with no Reverb. Its purist-pleasing front panel and distinctive roar set the standard by which all other rock amps were judged. And it is still produced because of continued artist use, and of course by popular demand.
The only modern addition made to the JCM800 2203 is a tonally transparent Series FX Loop.
The amplifier is in excellent working order and cosmetic
condition. It is fitted with a set of winged =C= El34's and Chinese PM ECC83's
- just like they are supposed to be for the best tone.
More pictures on request
Looking for £650 ONO. Located near Oxford
Its heavy so I would prefer collection only but may be able to meet somewhere between Oxford and the end of the M40. If not then postage insured to UK os £50 Parcel Force 24.Base theme by DesignModo & ported to Powered by Vanilla by Chris Ireland, modified by the "theFB" team.
