Having played "satisfactorily" for a few years, I recently decided to try to up my game and attempt to improve in all areas especially technique.
I decided to right back to basics and have disciplined myself to follow the Justin Guitar course to hopefully banish a few bad habits.
One of the exercises I've been practising recently is running up and down the major scale, against a metronome, gradually increasing speed.
Justin emphasises the importance of maintaining alternate picking while doing this, but I've been tending to fall back to economy picking as speed increases,
Is there really any practical, musical benefit in trying to force myself to maintain alternate picking in this way?
Is it such a bad thing, technique wise, to fall into economy picking when it feels more comfortable?
I alternate between picking at 55/65/75 bpm and 50/60/70bpm per practise session.
Keeps things varied. I have a few exercises for doing this, but any good "how to play" book or DVD will show you these or plenty more. Mine are the Troy Stetina series, but I have others too.
I also don't just pick on one string, use 2 side by side, or try string skipping as well.
I have 3 exercises for making sure I can pick accurately at each speed. If not, I'll slow down to a point where I can.
Then when my picking hand is working accurately I'll vary the exercises so I'm not just going over the same pattern each time.
This is why I make sure my picking hand is working at lower speeds first.
Also I vary quavers, semi-quavers and triplets. I only ever let myself go full-up after getting my picking right at lower speeds first.
Also, practising this* for (say) half an hour a night, is better than 2 hours once a week.
If I practised on days 1/2/3/4/6 and had a break on days 5/7 the days immediately after the break my playing is a bit behind where it was before.
*same for anything.
I still run up and down a lot with strict alternate picking. I think you will benefit from getting that solidly into your technical repertoire. If you are gravitating towards economy picking and are happy with the timbre that produces, then certainly stick at it. My own playing contains a mix of Alternate, Economy, Legato and Hybrid picking that (via practice) all fit together without a second thought now.
The various picking styles offered up by Justin, Troy Grady, Marty Friedman, Frank Gambale, Yngwie, Steve Morse... whoever, are all their personal solution to expressing themselves through the instrument.
Try as many different techniques as you can find and develop your own way from one or more of those. There is no one right way of playing. If it sounds good, it is good.
The rest of that post is superflous
You're right. But the practice of running up and down them, will mean that when you need to play a run as part of a melodic solo, the coordination will be there for you to do so.
If you listen carefully to your favourite solo's, some of them will be snippets of exercises connected together cleverly so they no longer sound boring. It's only how and when you use notes or techniques that makes them good (or bad).
Twisted Imaginings - A Horror And Gore Themed Blog http://bit.ly/2DF1NYi
i think now alternate is probably the most important to get right for a few reasons ...accents are better and easier in your playing with alternate .....you dont have to think about certain runs that only ecconomy picking will fit by starting on certain notes ...or legato not being possible on such and such a run because it falls wrong on the strings ...wherever you are with alternate you can go wherever else you need to be cos you are not limited....saying that i think all should be learned but dont neglect alternate ....its also the basis of economy ...
My warmup is using fingers 1/2 frets 5/6 go from low E to high e, then high e to low E.
then finger 2/3 on frets 6/7 same low - high then high - low
then fingers 3/4 on frets 7/8 low - high high - low.
All so you play each string twice.
All on a regular 50 or 60 BPM
I also do fingers 1/3 on frets 5/7 and fingers 2/4 on frets 6/8.
Again on 50 BPM. and literally play on the click. This is only the warm-up, hence it's played slowly.
