FS - Reverend Kingsnake 20/60 1x12 Combo - *SOLD*
Probably needs new tubes, has the originals in (Now 10 years old).
The amp hums. I've had it checked by a tech (Malcolm Hine), caps are fine etc.
They made 300 of these I believe.
Designed by Joe Naylor and Dennis Kager, they made a boutique style amp and tried to mass produce it.
That ended up being too costly so they stopped.
2 x 6L6
2 x 12AX7
Tube reverb
Switchable 20 / 60w
Switch to change voicings. (British, American and lofi) (Lofi is kind of meant to be Supro sounding)
Jensen Neo100 Speaker
4, 8 and 16 Ohm output.
Really light (13kg). Really loud.
Has converter sitting in the bottom to go from US to UK voltage. (You could remove this if needed).
I believe it's a Jensen NEO100.
East Finchley (North London)
Only selling it because I'm not doing a stereo rig anymore (Also I'm moving at the end of the month).
It's the loudest lightest amp I've ever had.
I also like that it's unique.
