stacking pedal internals
Am I wrong in assuming that it's possible to put more than one circuit in an enclosure - daisy-chaining inputs/outputs and power supply ins/outs (assuming they're both std. 9v) in a way that would imitate connecting separate pedals externally ?
I don't have a particular example in mind at this point, but I have been considering the possibility and just wanted to be sure it's not a crazy idea.
  • GIJoeGIJoe Frets: 213
    No problem - I would recommend using multiple switched jacks though, so you can place each part in a different part of the pedalboard like they were 2 pedals, or cascade them into each other (does this make sense?). E.G:
    A -> B or A -> Wah -> B
    "Nobody is really researching robot jokes"
  • chrispy108chrispy108 Frets: 2336
    Yup easily do-able, and I was going to suggest the switched jacks before GIJoe did.
    You only need one power jack, you just connect the jack to the 9V and ground of each circuit internally.
