Hi all,
Installed a set of Bare Knuckle Rebel Yells in my Les Paul, and wired them as per 50's wiring diagrams (my old pups were wired the same way, so just moved the red lead (the hot one) from each RY pup to where the old hot lead was, and black and bare to ground).
The bridge works perfectly, but noticed today that the neck one seems to cut out after a while, especially after about 7 on the pot. It sounds very, very faint. If I pull and prod the wires, it kicks back in - just curious if anyone has any idea what this could be? I trimmed some more off the hot lead and re-soldered it, but same thing is happening.
Thanks!
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
Thanks!
If you don't have a spare you can apply extra solder under the lug, it should make the connection, at least long enough until you get a new pot.
