I own an old vertical input Marshall JCM 800 50 watt combo (4010). It sounds great but it's ridiculously loud. Louder, in fact, than an Orange Overdrive 120 I recently sold. I mean absolutely deafening. I keep waiting for the call from Angus Young to do a stadium tour on rhythm guitar for AC/DC, but he's got his cousin in the band now so it looks like I've missed the boat again. So I don't need the level of volume it's capable of.
I don't want to start chopping a vintage Marshall up (I did, but I've been talked out of it) so I've decided I'd like to build another one, with a less deafening power amp. (I don't want an 18 watt job. I have an 18watt Ampmaker P1800 I built. It sounds great, but it's not quite loud enough.) Just a pair of EL34s or similar turned down to something more like 30 or 40 watts flat out. I know this is rated at 50 watts but someone on here, possibly ICBM, says that's the undistorted rating, and that flat out he's seen the 50 watters churning out 80 or 90 watts when fully cranked. Which is how I use mine, albeit with an attenuator. But it's still too loud.
Just a thought but you could try part cathode biasing?
You probably want about 330-360 V HT and maybe play around with the screen supply voltage.
Top Men will surely be on the case post wheatybangs...
Dave.
Cathode-biasing is a good call. Although it will only reduce the power a bit, it will make the amp much more compressed so it will seem less overpowering.
Also, here's an odd thought - try disconnecting pin 8 (the suppressor grid) on each EL34. I recently came across an amp someone had tried to convert from 6L6s to EL34s and had forgotten that you need to connect these to ground. To my surprise since I always assumed it *must* be done, the amp worked and sounded more or less normal but was low on power.
You could also run them as triodes - connect the screen grid resistors to the plates instead of the B+ supply - but that produces quite a muddy sound as well as less power, to me.
Ah! Glad you agree about cathode biasing, just a hunch!
I would guess dissing the suppressor grids would turn the pentodes into "kinky" tetrodes and thus distortion start earlier?
Strapping as triodes is going to drop the anode impedance quite a bit I shall see if I can find out just HOW much.
Fatfingers, PM me.
Dave.
Not enough to matter. Marshall do this on the Jubilee and JCM900 amps - it gives about 50% of the power, but to me it changes the tone in a not-good way as well as reducing the volume, so I'm not really a fan.
"Not enough to matter. Marshall do this on the Jubilee and JCM900 amps - it gives about 50% of the power, but to me it changes the tone in a not-good way as well as reducing the volume, so I'm not really a fan."
Plus of course the PI and other stages have to provide substantially more drive voltage.
Dave.
