I have a Schecter Hellraiser Solo 6 which has EMG active 81tw/89 pickups. Frankly, I've tired of the sound and fancy putting in a new set of passives, something which sounds more real and versatile.
First question is: is it a lot of work and how much will I need to replace? The input? Tone and volume pots? Any advice on what brands and where to buy from?
I love the guitar - it's mahogany with a maple top, rosewood fingerboard and, much as it is a chunky bastard neck-wise, I just enjoy playing it. Any suggestions on pickups that will allow me to get somewhere into metal tones but can be tamed enough for lighter rock/blues tones? Must be coil-tappable/splittable.
As always, thanks.
I changed my EMG's for Di Marzio's.
Basically removed the lot, and put all new in. The jack is original (actually not, but the point is, it's the same), I *could* have used the same pots, but one was scratchy and nasty, so I changed the lot. No point in changing pickups and not spending the extra £notmuch for decent pots. I also put in coil splits, on toggle switches. Total was around 4 hours to do (make new loom, solder and fit).
I went with a Fred in the neck, and a Virtual Hot PAF bridge.
If you're unsure, the @Van_Hayden or @TheGuitarWeasel are good blokes who make pickups and will advise you on custom wounds.
My band, Red For Dissent
@ICBM, I have a different guitar which has always had dodgy electrics. It has a single tone/volume (Schecter Tele-style), push-pull coil-splitting. Would I buy pretty much the same components you've mentioned for i
You will also need a wire to the bridge.
On normal passive guitars it's already there. On active guitars its usually there, but taped off somewhere as its not needed with active pickups. On some its not there at all.
Its worth taking a look to see if there is already a wire going to the bridge taped off somewhere in the cavity. Adding one is a bit more tricky if you are not comfortable standing over a guitar with a power drill at an extreme angle
Instagram
