Screws made of cheese
Thanks, gotoh. Your tuners are excellent.
No really. They're lovely, nickel finished and work a charm.
It's a shame that you are aware of how bad your screws are - so much so you include spares in the box, for when one inevitably strips half way in and needs grabbing with pliers to ease out again!
Rant over. I'll fix it tomorrow.
  • GassageGassage Frets: 30939
    I often have a cheesy screw. It just happens when it happens and if' I've not showered, so be it.
  • ecc83ecc83 Frets: 1638
    edited September 2015
    I take it the screws are brass?
    If so, trick is to run in with a steel jobby first and a touch of lubricant is also advised. Candle or hard soap  are two good ones but beware that soaps can discolour some woods.
    Dave.
  • CorvusCorvus Frets: 2929
    Hate that shitty DIY-screw type material. Worth binning 'em and getting stainless ones.
  • WezVWezV Frets: 16748
    I haven't noticed the gotoh ones to be that bad. If they are cheese then the Harley Benton ones must be yogurt. All screws get a bit of wax on the way in.
  • Yup, waxed the screw, same as always - it's a bit of a crap shoot. It came with 5 screws more than needed and of these, two stripped really, really easily with a perfect fit screwdriver.
    The others were pretty good, went in no trouble.
  • impmannimpmann Frets: 12669
    You *have* to pilot drill these, then wax them and use a good quality screwdriver of the right size and type. You'll be amazed at the number of people who dont believe there is a difference between pozi drive and Phillips, and that there are different sizes of tip...
    That's just gross!
  • 4114Effects4114Effects Frets: 3131
    edited September 2015 tFB Trader
    Agreed. The only screws I've ever had break are when I was silly enough to think I could get away with not drilling a pilot hole. Or very rarely when the pilot hole was not the right width or depth.
  • ThePrettyDamnedThePrettyDamned Frets: 7489
    Yup, pilot hole *and* waxed.
    Correct size hole, perfect match Philips (not pozi) screwdriver.
    Just ruined the head immediately - luckily there is loads sticking out for me to grip with pliers and a rubber band, but it's still very frustrating. They are plated in something,and the neck is maple so very hard.
    God knows how you'd screw into maple without a hole!
  • jd0272jd0272 Frets: 3867
    usedtobe;769743" said:
    [quote="Gassage;769563"]I often have a cheesy screw. It just happens when it happens and if' I've not showered, so be it.
    That's just gross![/quote]
    That's just James. I'm sure he washes most days. ;)
    "They are plated in something,and the neck is maple so very hard. "
    M3 tap and machine screws? Button headed Allens would look cool.
    Dave.
