One thing I've been trying to do at jam nights/practice etc, is roll my volume back for the quieter parts of a song, and whack it up to full for a solo etc. I'm finding that when I play alongside another guitarist (one in particular), I can hear myself during the rhythm parts, but when I turn up for a solo, it makes little difference and I get entirely lost in the mix. One or two have advised me to get a boost pedal, but part of me thinks perhaps the other player needs to turn down a little.
The other thing that may not help is amp placement. Our amps normally wind up on the same side of the stage, so it could be that I'm not hearing myself clearly enough.
Sorry for the train of thought rambling here - any thoughts or advice would be appreciated.
@ICBM I can see what you mean re. increasing overdrive. The other player uses a Dime signature with humbuckers etc, and tends to play with heavy distortion through a 100w combo. I tend to play a Strat HSH through the house 100w half stack. I try to get some slight crunch for rhythm, and some more overdrive/volume for lead work etc. That's the idea anyway!
As for the positioning, it may be possible to put one over the other side near the bassist - maybe I'll take my own 100w combo and do that.
I think a boost pedal is looking like an option, just to try...
A common complaint is that "guitarists are always too loud". But something I've always maintained is that no one ever gets told they're too loud when they're playing a solo (well, assuming it's still below the pain threshhold) - it's always the bread-and-butter rhythm playing that gets moaned about.
Part of playing with multiple instruments, especially two or more instruments occpying the same sonic spectrum (i.e. guitars), is controlling where you sit in the mix to be appropriate for the part you're playing.
If you blast out all over the vocal sections of a song to the point the vocals are inaudible the singer is going to moan at you. Moreover, you're not doing your job very well - at that point in the song, the vocals are the focus and you should be supporting them, not drowning them out.
Similarly, if your rhythm guitars are blasting out to the point the lead guitarist becomes an inaudible comedy mime artist - you're not doing your job very well.
Another point I'd make is that the difference in level needed between your rhythm and lead sounds is very much dependent on the size and composition of the band. In a guitar/bass/drums set up you don't need an awful lot of a volume hike - maybe even more of a mid-boost than volume boost will do the job. In a 15 piece band, though, the difference between your rhythm sound sat in the mix and your lead sound rising above all that can be quite substantial.
I use a TC spark boost in clean mode for solo breaks.
Guitar volume roll off is nice but could be tricky to get perfect at a gig whereas I think a boost works every time.
Others know way more than me about this, though..
My YouTube Channel
