Hi all,
Bit confused and frustrated with this new PA myself and my band have purchased...
Basically, our old one was a bit weedy, and we're playing larger venues now so need something with more power. As such, I purchased a Behringer PMP2000 powered mixer (800W) and a couple of 12" Passive speakers (8 Ohms, 600W per unit).
We've set it up in rehearsal, and are getting pretty nasty feedback and clipping, even though it should be a lot more powerful than the old one!
Now, the way we have it connected is via the right mono output (speakon to jack adapter) into one speaker, then connect the other speaker to this speaker. I have also tried the Bridge output, and that was even worse.
Does anyone have any ideas of how to set it up correctly for these speakers? It's driving me mad!!
Thanks
Our band uses a BEHRINGER EUROPOWER PMP1680S as a vox p.a. which has proved up to the job for us and keeps up with a Marshall backline ok. Has the advantage of a feedback detection tool.
Danny is right the manual states 165 watts per channel at 8 ohms (I take it you have the manual ?)
http://www.manualslib.com/manual/214307/Behringer-Pmp2000.html?page=9#manual
Suggest as a start you use left and right mono outputs and follow the instructions on the manual. What are you actually using it for?
I'm using this exact PA for vocals and ocassionally for all instruments into a bigger PA (I posted about this a while back)
Works great for use, no feedback issues other than what you'd expect (putting mics in silly placed) and plenty of volume for your usual pub size gig.
We run a single speaker from each output (left and right) as @icbm suggested.
As he also suggested speakers make a huge difference, we went from some unbranded ones to a set of rebadged peaveys - still not exactly top of the range kit but the difference was amazing and the vocals much clearer and warmer.
From the look of it, the mixer outputs about 500W per channel in 4 Ohm mode and 320W in 8 ohm mode.
Now - is it ok to have the monitor connected by daisy chaining from one speaker? Can't use the other amp and have the front of house connected to the other power amp as they are 4 ohm speakers and I believe they would need to be 8 ohm when connected....
