Tolex (again): What glue?
Hi - I've just finished a 5E3 variant and have a cab that I need to cover. I've got the tolex but was wondering what glue to use. Last time I did one I used white PVA and, to be honest, it was rubbish. No adhesion and took ages to dry. Everything mentioned on the USA websites doesn't seem to be sold over here?
So, what glue is best to use, that's easy to get in the UK?
Also, any good You Tube tutorials or websites on how to cover cabs? I did an OK job on my last project but fancy doing a bit better this time.
Thanks!
  • martinwmartinw Frets: 2149
    Timebond.
  • stevehsteveh Frets: 232
    martinw said:
    Timebond.
    That is exactly the info I need; thanks for the rapid reply.
    No worries.
    Spread it with an old credit card, and disposable glue brushes for the fiddly bits. It's about £8 for a 500ml tin in B&Q.
    martinw said:
    Oh, and wear a mask.
    If I don't, do I get high?!
    Yes.
    If by 'high' you mean splitting headache, nausea and possible liver damage. :D
  • martinw said:
    Yes.
    http://media.giphy.com/media/mUUUWD7UEE1qM/giphy.gif
  • DeadmanDeadman Frets: 3924
    The RAF used to supply us with evostik 528 for internal aircraft trim. It was superb stuff.
    Have you ever tolexed the inside of a Harrier?
    I bet it would look awesome !!!
    "Establish the possible, while gradually moving towards the impossible" Guitar Craft aphorism.
  • JohnBJohnB Frets: 121
    Tolex the outside, that would test the glue! and it would look cool
    You jest but there were plenty of VC10's and Tristars that were trimmed in similar materials. I used to run a bay at Brize Norton that did just that.
    Actually we used to use Evostik 528 for formica as its quite thick. For tolex and lighter materials we used to use Evostik 613. We got a highly professional finish every time with this, quite important when we were dealing with VIP aircraft:
    https://www.cromwell.co.uk/EVO7133018M
    Timebond duly purchased today; thank you gents.
    I trust 1\2 litre is enough for your needs. We used 5 litre tins like they were going out of fashion. Works out a hell of a lot cheaper, mind.
  • hywelghywelg Frets: 4303
    I have used pva extensively. I also use a hot air gun to dry out the glue on the edges which then turns it into contact adhesive. The heat helps when moulding the corners makes the tolex more stretchy.
