Edit - this one though you can find it under £20 if you look around. It also comes with an attachment which helps get into small nooks and crannies
http://www.amazon.co.uk/DECKER-KA161BC-Detail-Sander-Accessories/dp/B001G7PR3Q
Always follow the grain when sanding, especially if you're going as low as 80 grit.
I use the heat gun method/smooth edge paint scraper now, keeping it a good distance from the finish, the idea is to warm the poly, not melt it, if its bubbling you're too close/not moving it around enough.
Carefully around the bindng though!
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
http://www.thefretboard.co.uk/discussion/44392/westbury-standard-gettin-nekkid/p1
