ooops! minimum depth for headstock?
I had a cock up on the routing front a while ago, and accidentally took a chunk off of the front end of the headstock. I was thinking that I would put some kind of veneer over the top to hide it, but then I wondered what the minimum thickness for a headstock would be? If it took this out then the thickness would be 12mm - not enough?
