The only player I've seen who does a lot of big bends, but just uses one finger is Eric Clapton. It seems to work fine for him.
this....
use as many fingers as you need / as the lick leading into the bend will allow
keep your fingers still, stiff and as straight as possible
anchor your hand on the underside of the neck [with the bit between the thumb and 1st finger] to function as a pivot
the bend comes by rotating the wrist [so the power comes from the forearm rather than the fingers]
where possible [general rule, but not absolute] pull the 3rd to 6th strings downwards, push the 1st and 2nd strings upwards..
btw - vibrato is exactly the same technique because it is lots of smaller bends one after another...
so master one and you can master the other..
