telecaster body weight relief
My tele body is a bit heavy so I'm going to cut a couple of chambers and put a cap on top. Is there any 'science' involved or can one just hoof some wood out? I figure that leaving all the centre section is pretty logical for general strength. This is what I am planning to take out (unless advised otherwise!)
  • WezVWezV Frets: 16815
    that will be fine.  You can also take out all the control area too for extra weight loss.  I would normally do behind the bridge but if makes sense to leave that solid with the bigsby
  • axisusaxisus Frets: 28347
    Thanks. I had visions of dropping little screws etc into the controls cavity and cursing trying to shake them out, so that's why I left that bit solid.
  • ecc83ecc83 Frets: 1640
    I don't suppose the cavities WILL resonate but a few cotton wool balls would stop any possibility.
    Or fibreglass or rockwool or BAF.
    Dave.
    Dave.
    Good point. BAF?
    It won't be an issue. Don't add anything to the chambers
  • IvisonGuitarsIvisonGuitars Frets: 6842
    This is what GSP does with his ash bodies as far as I know, mine certainly has it. Lovely lightweight thing :-)
    http://www.ivisonguitars.com
    (formerly miserneil)
    Got some 2.5mm Maple to go over the top, but it doesn't feel that substantial at that thickness, I think I may double it up.
  • BigMonkaBigMonka Frets: 1784
    Keeping the control area solid (like you've shown) may help with balance on a strap, I find my thinline can suffer from a bit of neck dive.
    Depends really. Did you weigh the body? The amount of chambering you have shown will tike it down by 20-25% at most
    Maple sawn to 2.5mm should be strong enough but would need a couple if strips inside the control cavity. I am less sure about a cut veneer at 2.5mm, but I think it would be weaker than sawn. Not even sure if you can get cut veneer as thick as 2.5mm but I have had cut up to 1.5mm so assume its possible
    Weight 5.5lb At present. I think I'll rout the chambers then see how the maple feels in place. Cut vs sawn veneer - does it make a difference?
    I believe cut is weaker, possibly treated before being cut... I can't remember
