I have Beyerdynamic DT880s, I like them.
It's also really worthwhile having something like the Avantone Mixcube.
Check mixes in Mono on a small closed cabinet speaker. If you can get a balance there and on a decent set of headphones you'll be much further along than if you just used bad monitors (Or even great ones) in a bad room.
All this for mixing.
I wouldn't ever call any track I've finalized at home 'mastered'.
Anything I've wanted done properly has gone to an actual mastering engineer who specializes in only that.
Bandcamp
Spotify, Apple et al
Closed back ones tend to fiddle with the bass. As @cirrus said, you want the flattest ones you can get.
Mixing with Headphones:
http://www.soundonsound.com/sos/jan07/articles/mixingheadphones.htm
Headphone calibration software is now available, if you want it
http://www.soundonsound.com/sos/may15/articles/sonarworks-reference.htm
Bandcamp
Cirrus is dead right in that when tried side by side it's staggering how different relative pairs of headphones can be. It's the same with monitors too. With both my advice is always spend time acclimatising yourself to them by listening to music that you are REALLY familiar with and/or that which is in the ballpark of where you want to be over and again.
IMO more important than the particular monitors, headphones or space is familiarity with it. It's one of the reasons for the NS10s success in that they where predictable in their environment that even when moving to different spaces producers and engineers could have at least one reference point of familiarity whilst acclimatising to the rest.
I feel there are as many pitfalls with headphones as with speakers (if that SOS link is the same article I've read, even they say to listen on monitors to judge bass end mixing decisions.
Get to know your mixing evironment, position whatever speakers you have in the room to minimise problems, maybe even acoustically treat the room to whatever degree is achieveable.
One thing that drastically improved my mixing evironment is placing the monitors on Auralex MoPads - blocks of acoustic foam that acoustically isolate the speaker from the desktop it's standing on. You could probably save money and just get some pre-cut acoustic foam blocks from somewhere like eFoam.co.uk and DIY a pair.
While a bad room with cheap speakers may give you unrealistic results, bear in mind that if commercial releases ok on that setup so should yours.
To that end, I have a folder of commercial reference tracks in various styles to which I constantly cross refer when I'm mixing.
It may be an age issue, but I don't trust the objectivity of my ears or my audio memory for more than about half an hour these days, without going back to some reference material to find out how far I've drifted from my goal.
My YouTube Channel
My YouTube Channel
Bandcamp
