I have a slight issue with the Floyd Rose on a recently bought guitar.
I've been using Floyds for many years and am confident in setting them up and am fairly sure this isn't a set up problem, but I'm looking to the experts for advice....
The issue is that after using the trem it doesn't return to pitch - it returns flat and out of tune with itself. A little lift to the arm seems to resolve this and it then remains at pitch.
I think that this may be down to the base plate slipping out of position on the posts and needing a little upward lift to seat properly after use - it also seems more of an issue on the treble side.
The guitar is 25 years old but in near mint condition, the bridge is a proper Schaller one and as far as I know the two posts are also original - they appear to be screw in ones with a flat / straight screw top (rather than Allan key type). I haven't removed any parts to investigate but am confident to do so if I need to.
When not using the bridge tuning is spot on and Ive set the intonation correctly etc - it is just this issue with returning to pitch after use.
Any thoughts?
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I'll dismantle, inspect and clean as required. It's currently set with 3 springs so I will try with 2 as well and see if the extra tension improves stability.
Will get back to you with an update once Ive had another look at this.
I've removed the bridge and had a look at the condition - both the knife edges and the posts looked good, but to be sure, I gave them a quick clean with a cotton bud and some eye make up remover (yes, I know...) and some gunk came off. Holding the bridge back in situ and manually pivoting it, it appeared smooth and problem free but when pushing it down (as if upward bending) revealed that the rear side of the trem arm mount snags on the edge of the block cavity - of course, this is on the treble side so fits with my theory that problem is more significant on the treble side. This was probably not an issue for the previous owner as he had the bridge sitting higher, but when I lowered the action this would have become more of a problem.
So, my next question ( @Fuzzdog @Marshall_stax @Maynehead @FelineGuitars and anyone else...) - keeping in mind that I have no specialist tools, what do you suggest for me widening the cavity a tad (it really only needs to be a fraction of a mm) neatly and with minimum risk to damaging the guitar?
Here's a picture showing where the arm mount has been catching:
http://i1193.photobucket.com/albums/aa356/revmatt1/P1040649%201500x1125_zpsracqzt8f.jpg
Gents, thank you all for your help and advice - all sorted!
I took it gently with the side of a drill bit and that seems to have done the trick. As you'll see in the picture I only had to give it a tiny bit of extra width, but it's resolved the issue. Having now reassembled the guitar I've set it up with lighter gauge strings so also followed the 'one less spring' advice. It's now playing great and returning to pitch smoothly.
http://i1193.photobucket.com/albums/aa356/revmatt1/P1040650%201500x1125_zpsrs4ixrow.jpg
And just to put it in context:
http://i1193.photobucket.com/albums/aa356/revmatt1/P1040630%201500x1061_zps1i5tsuit.jpg
The guitar is a Patrick Eggle from 1991, but for those who are interested, it's not a production model. It may well have been a prototype or an early build before the company really got off the ground - either way, it's a cracking guitar :-)
Thanks again to all who offered advice.
