Reverb stopped working
harpoharpo Frets: 177
edited November 2015 in Amps
On my blues junior. It was working three weeks ago and it's been resting in the garage since then. Plugged in today and nothing of reverb comes through even when dimed .....does this mean a replacement unit??
  • vizviz Frets: 10710
    Does it boing when you kick it?
  • harpoharpo Frets: 177
    Haha when it's turned on do you mean?
  • ICBMICBM Frets: 72512
    Try wiggling the two connectors to the tank first, or take them out and spray a bit of contact cleaner or WD-40 on them. If it's been in the garage for three weeks a spot of corrosion could have occurred there.
    If it's not that it is likely to be a problem with the tank, and unless its one of the very newest amps with a Ruby one, it probably will need replacing - the Accutronics ones can sometimes be repaired but it's not easy and not always possible.
    Replaced tank with a new one and still nothing. Grrrrr
    Does the Fat switch still work? The switching is driven from the same power supply that feeds the reverb. If it doesn't, it will be something in that supply. If it does, it's probably the reverb drive/return IC.
