OK, so I have an amp WITHOUT an effects loop. I want a simple box that I can put in between the speaker output on my amp head and the cab, with a line out that can tap an instrument level signal out via a 1/4 jack which I can then run through some effects pedals and into the PA. I want to add in some effects (mainly delay/ reverb) post amp distortion. Kind of like a Suhr ISO Line Out but with a built in speaker sim so I can run straight into the PA and not into another amp.
Does it exist? All the boxes I've come across are line/mic level outputs via XLR.
Any suggestions?
If you want to get more sophisticated (i.e. expensive) the Torpedo Cabs load/direct boxes seem to have a really good reputation..
I'm basing this on an older version of the Red Box that I've got tucked away somewhere (but haven't used for years). My memory is that it has both 'speaker through' (jack) and 'line out' (XLR) outputs. There is a newer version of the Red Box with various switches on it - I have no idea if that version has the same outputs.
