Could upgrade the earphones to something like the Shure SE315 or ACS T15's
Works great, sounds good, lots of isolation, earpieces are comfortable, plenty of oomph etc.
I'd never used IEM's before these, but I have to say that I really like them.
If you've never used IEM's either, you'll probably find this setup will be leaving you thinking, "why didn't I do this sooner?!"
It works great and sounds good. The bass response is good also. I did think about getting a more expensive setup, because, why not... But pleased I didn't. These will suffice for pretty much any application IMO.
I normally tend to only have one ear in because the noise isolation with the Shure SE215's is really good and not enough sound would bleed through otherwise. I've been told by other band members that the Soundmagic earphones are a good compromise because they don't isolate sound quite as well as the Shures.
