So, as i've been procrastinating, pondering, searching etc for a small but powerful yet inexpensive amp (aren't we all?) i've read a lot of posts or adverts/descriptions that have mentioned the phrase "really loud considering it's only XYZ watts" or the like.
That got me thinking - is there such a thing as "really loud for the wattage/size"? I mean, I know it essentially comes down to the amount of air the thing can move, but would a 12 watt 1x12 combo be "louder" than another 12 watt 1x12 combo?
If so, what would the main contributing factors be?
This week's procrastination forum might be moved to sometime next week.
Ah ok! Hadn't thought about that...
Bandcamp
Spotify, Apple et al
Lower frequencies require more energy to reproduce. So in theory your watts will go less far..
Speakers also matter as stated above. I think they can vary in efficiency by as much as 10dB or so. Maybe a bit more, maybe a bit less.
But, even a sensitivity difference between drivers of 2dB can have quite a noticeable difference in their perceived output. Then you also have to account for impedance too.
Quite a few variables.
I always find the simpler amps to generally sound louder, though.
For example a Dual Rectifier is rated (by a certain yardstick) at 100w.
A Marshall 1959HW is rated (by maybe a different yardstick, granted) at 100w.
I would bet my last quid that with the Boogie at full tilt, you could easily drown it out with the Plexi. They deliver their power like nothing else.
I used to get moaned at for being too loud with my Sessionette 75 being on 2 with an overdrive pedal into the front end.
Seriously, it had more to do with his thick, syrupy middle honk sound that modern Marshalls seem to develop. Frankly it was horrible - it was like a nightmarish version of Slash with a blanket over the cab. No amount of eq solved it.
Eventually he borrowed a plexi reissue a gig with a booster into the front end - same cab. Fuck my Wellington Boots was that loud!!!
These days, I gig with a different chap who has a Hayden Mofo 15 - that can get pretty loud and despite some people's reservations he makes it sound great. He also has a JCM800 50w head (later one with reverb) - whilst that can get fairly loud, I prefer the sound of the Hayden and I think it cuts through the mix better.
Oh and AC30s? Back in the 90s I gigged with three... monumentally, stupidly, ridiculously loud. Ultimately pointlessly loud too!! Amazing amps, though...
"Play along with" - surely?
On offer here at £14.
http://www.tool-net.co.uk/p-426844/silverline-905722.html?gclid=CMq0sPW3sMkCFda4Gwod2fcCbw
