As you will know from my other posts re my first gig in 30 years, I was going to get some advice re my amp which completely went berserk at the end of the gig - into a wall of distortion, which I couldn't make head nor tail of in the heat of the moment.
In the cold light of day and on closer inspection it turns out that there is nothing wrong with my amp at all (quite a relief tbh) and the problem was down to some serious (and amusing) user error.
Having taken some of the "top tips" to heart, we thought it would be a good idea to have a kind of "stage look". Dinner suits and brothel creepers were the verdict (don't ask). In all the excitement of an encore and being unaccustomed to brothel creepers (something else that only come out every 30 years) I'd kicked the pedals all over the place (a knob had even come completely loose) so that all of a sudden nothing made any sense anymore. Sign of a great gig.
Despite many years experience, we had a gig this Saturday where we had to set up in silence behind the stage curtain while others performed acousticly in front of it. No chance to test the pedal/amp features properly. I have amp hiss and the signal into the tuner is good.
Curtain goes back, band exposed and I have no sound! Panic sets in when obvious things (at the time) are checked, i have an input switcher with mute so several possible combinations possible. Still nothing more than very faint signal. Guitar straight into amp - fine! tuner reads. All patches checked and secure but wont pull out because of screwed down location. Finally after what seems like an age I realise the input volume on the echo unit is wound down. Also in all the bending over etc. I've upset the traditional Tele jack socket too! Longest 15 seconds of the night.
After that it got a lot better very quickly, so even us old hands get it wrong sometimes.
Came back on after the souncheck, launch into first song - silence from my amp. Band comes to a halt.
Guitar up full - check. Signal level lights on FX unit - check. Amp volume turned up - check. Just to make sure I turn it up further. (ie pretty much full.)
I think something must have blown in the amp, so lean over the back to look at the valves - glowing normally and lighting up really bright blue when I strum the guitar - amp definitely working.
Then I look down and somehow spot that the speaker cable is pulled halfway out of the jack in the cabinet - an old Marshall 4x12" so it's at the bottom - it turns out the drummer probably caught it with his foot on his way back behind the kit. I can't reach it so I ask him to push it back in, which he does.
Now bear in mind that as the cable goes back in, I am leaning against the front of the cabinet with the guitar directly against the top two speakers and everything turned up full... and it's a Telecaster with a slightly microphonic bridge pickup .
The opening tune of our very first gig started with me playing a D to E riff and then the band come in
After being announced by the host I boldly stride to the front of the stage, raise my hand to the air and adopt the pose
Only when striking the strings did I realise I'd left my amp on standby ....
And I thought the walk to the front of the stage was long .......
