Good day at Andertons that!!
You do know that one of the issues with the RAT amp load box is that it is a passive load?
I just recently switched to recording more direct with impulses. I built 2 active load boxes and the difference is really noticeable. Using the passive load box I keep for testing I was getting the same buzzy low end you speak of even out of a Tweed Deluxe and on the Laney's clean channel, which comparing the impedence curve of the passive to the active box it actually makes sense why. The total cost of each one was around the £40 mark. I can send you the plans if you like? The parts are a bit of an arse to source in the UK but I found them and on checking they are still available.
