Preamp valves (paging knowledgeable types)
LooseMooseLooseMoose Frets: 932
Hi all,
So, it's often heard that for 'taming' the gain of an amp with too much of the stuff, a preamp valve swap is a good idea.
I have a Fender Deluxe VM and love it but I find that with hot pickups, even 2/3 on the gain control on the drive channel is a little too much.
I'd like to calm it down, so a 12AT7 or 12AU7 seems to be the general plan - is there any way that in doing this, I could harm the amp?  Are there other side effects that I should be aware of?
Thanks in advance,
James
  • ICBMICBM Frets: 72825
    Yes, you could harm the amp - not very likely but theoretically possible. It depends on the components chosen and what happens to the voltages with a different valve type, so without access to the spec sheet and an amp to measure the changes on you won't know for sure.
    I would say there's at least a 95% chance it will be fine but if that last 5% worries you, stick to a 5751 which is the only definitely safe substitution for a 12AX7.
  • Thanks mate - 5751 seems the safe option. Worth changing ALL of the 12ax7s do you think? Or just the first...
  • strtdvstrtdv Frets: 2473
    Just change V1
    I actually have one amp that I use an old military spec 1960s 12AT7 in V1, have done for years.
    It shouldn't sound good, but it does.
    12AU7 is much less gain, you'll reduce the volume/gain of your amp hugely if you use one of those.
    Thanks mate - 5751 seems the safe option. Worth changing ALL of the 12ax7s do you think? Or just the first…
    It depends which valve(s) affect the overdrive channel and/or if you want to alter the clean sound as well. I'm not familiar with the valve layout in that amp though.
  • i use a mkii mv lead for bass and my amp guy suggested i tame v1 and use the low input. i used ecc82 and ecc83, but he suggested 5751 as it is a lower-gain ecc83 and the circuit was designed to suit the ecc83 valve
  • The wrong valve will cause a lot of hiss/buzz.
