I'm having trouble getting a decent solo volume boost using my new JCA22H.
I've tried both an EQ pedal and my SHO clone in the loop, but they just seem to increase the gain rather than the volume.
I've also tried using the crunch channel fairly clean (gain position 1, master position 5), and boosting using my SHO for my main sound. I then use the overdrive channel (gain @ 4), master @ 7, but it's still not a noticeable volume increase.
Is it a simple lack of headroom, or am I doing something else wrong? I've come from a Blackstar HT5 which I used to boost via the loop without a problem. Oh, I should add also that I'm using a Jettentuator which is pretty much fully open.
