Good afternoon ladies and gents!
In a trade I recently acquired a princeton reverb II, probably my perfect amp! A beautiful blackface clean channel with reverb to use live with some pedals for some extra dirt and a lead channel with master volume so it's still usable at home levels! However after a little bit of playing time I've noticed it just cannot put out any decent amount of bottom end on the lead channel and there are some horrible harmonics going in in there....
At first I suspected the speaker, but after trying it through a speaker I know is fine and having the same problem I figured i'd try a new set of valves, both power and pre (luckily I had all the valves I needed in my parts box) but again, no change.
So I can only conclude that it's electrolytic capacitors needs replacement. I was led to believe the amp had been recently serviced so assumed this would have been done, but after opening her up I can see that all the capacitors look to be original.
Being a hand wired amp I'm perfectly happy to do this job myself, I have abit of an electronics background, have built a couple of valve amps so understand the dangers and its always satisfying to do your own maintenance.
But I do have a few questions.
1. Does anyone have any other suggestions of what could be the issue?
2. Does anyone know of any reasonable priced supplier of cap cans in the UK? I've found a suitable replacement in the US at a fairly reasonable price, but would prefer to not have to import (specifically I need a 80/40/30/20uf 450v can)
3. Does anyone have any suggestions for capacitor manufacturers? I'm leaning toward sprague atoms, but I'm more than willing to have my mind changed!
Anyway, thanks for reading and any advice you may impart!
Capacitors:
http://www.hotroxuk.com/amp-parts-service-equipment-294-0/capacitors-mallory-caps-sprague-orange-drops-6136-0.html
Resistors:
http://www.hotroxuk.com/amp-parts-service-equipment-294-0/resistors-7961-0.html
