So, I've been trying to work on my technique over the last few months - doing legato and alternate picking/scale exercises.
The problem is, I can play far better/cleaner with my thumb in the 'classical' position - with the thumb resting on the back of the neck. However, I naturally play with my thumb resting on the sixth string... Baseball bat style?
As a result, for some reason I find playing these exercises with my left hand in the second position is far more awkward and feels uncomfortable. It's almost like my fingers get in the way of each other.
Would you wise people suggest I try and adapt to playing in the classical style, or just practice these exercises with my hand in its natural position until they no longer feel awkward?
Q: When I practice what you tell me it works OK but when I'm out with my band and soloing I catch myself using my "old incorrect" technique, and try to put things right, and mess up the solo because of it.
A: When you play with your band, forget what I tell you. Just play. But keep practicing what I tell you, and in 6 months you'll find it is working its way into your what-comes-naturally playing.
So I'd suggest continuing to practice that "classical" positioning, especially as there are things you will probably need it for, and one day you'll be able to pull it out of the bag when you need it. In the meantime, if you have blues-rock reasons for using your "natural" style, continue by all means to use it as that's what it is meant for
This is something I've struggled with myself in the past Will.
I learned to play classically at first with the thumb in the middle, of the back of the neck. The trouble with that approach comes when bending the unwound strings; your fingers are already parallel with the frets so you have no wrist rotation left for the bend.
I tried re-training my fingers to play the Baseball bat way, which was like swimming in mud at first but gradually started to feel very cool. The only issues were that I couldn't reach down to the lower strings like that and some legato stuff was not as easy.
The solution arrived at was to transition between the two. In a classic 3 note per string scale exercise, I'll gradually turn my hand toward classical as I approach the lower notes. Then as I ascend, I return back to the bluesy relaxed hand position. Similarly when I play ascending or descending 6 note patterns I find I have to straighten up a little the lower I get, but need to get my fingers and hand back to 45 degrees by the time I'm near half way back up. It really works for me.
Take some time and experiment to see what suits you.
I think I'm going to either try to find a midpoint that works and adapt my vibrato (always wanted to be able to adopt the Clapton style), or just use both.
I'm one of those people with extremely long fingers, so sometimes I even find my thumb muting all bottom three strings when playing live, which, while useful, is not at all a comfortable way to play legato!
